Here is a tip for Nexus users with Wi-Fi issues
Here is a tip for Nexus users with Wi-Fi issues.
The problem being that you connect to Wi-Fi and a few minutes later it disconnects. You see that Wi-Fi is still turned on but all networks are showing as out of range.
A quick fix is to toggle Wi-Fi off then back on, it will reconnect to the network you were on but it will happen again very shortly.
The solution to the problem is to open the Wi-Fi settings and click advanced under the menu. Set Wi-Fi Sleep Policy to Always.
While you are at it, turn off network notification to save battery!
That's it! Really simple fix and I hope that it helps you!
