G+_Rich Fowler Posted October 11, 2015 Share Posted October 11, 2015 Someone on the Nexus subreddit posted a pretty easy way to turn on battery percentage as a number in Marshmallow. It works, but the resulting number is pretty small. You can also edit your Quick Settings bar like crazy if you want. https://www.reddit.com/r/Nexus5/comments/3obgvy/battery_percentage_n5_60_marshmallow/ Link to comment Share on other sites More sharing options...
