Help an Android n00b out!
G+_Erik Flees
Help an Android n00b out!  I'm getting a hand-me-down Android Device (Droid Razr Max) and I want to run as close to native Android on it as possible.  Can I do this with a simple launcher, or should I go ahead and root it outright?
Not afraid of the process, just don't want to do more than is necessary.
There are things you can do without root:
Calendar: Google
Keyboard: Google
Launcher: Soon to be Google or Nova/Apex
SMS/MMS: Soon to be Hangouts or ChompSMS/Handcent
Camera/Gallery: There is a downloadable version from the Google Play Edition One/S4 that works great, and also includes Photosphere.
I haven't found a good replacement for Contacts/People, yet.
The things that you can't change without rooting are things like notification shade, settings, and the look and feel of menus and such.
I find trying to do the faux native android thing can become really frustrating. Especially with little things like camera from the lockscreen. You might get something to work but it won't work seamlessly. ?
