G+_Joshua Gaede Posted August 25, 2013 Share Posted August 25, 2013 Does anyone else have a problem with google maps. I am trying to get directions, but it keeps showing no route found. It keeps putting me on a bus route and when I click on the car it pulls up nothing. Im using a galaxy s4 and I tried on the web on my mac. No bueno. Any suggestions? Link to comment Share on other sites More sharing options...
G+_Elizabeth Whitmire Posted August 25, 2013 Share Posted August 25, 2013 I was just using Google Maps on the web in Chrome on my Mac with no issues. Are you able to use it yet? Do other destinations work? Link to comment Share on other sites More sharing options...
G+_Joshua Gaede Posted August 25, 2013 Author Share Posted August 25, 2013 I can't get a route anywhere Link to comment Share on other sites More sharing options...
G+_Joshua Gaede Posted August 25, 2013 Author Share Posted August 25, 2013 I sent a ticket into Google hopefully it will work out Link to comment Share on other sites More sharing options...
G+_Elizabeth Whitmire Posted August 25, 2013 Share Posted August 25, 2013 Ok good luck Link to comment Share on other sites More sharing options...
G+_Stephan Powell Posted August 25, 2013 Share Posted August 25, 2013 I have noticed that the google maps on iPad app will not load, I just get a blank screen. Link to comment Share on other sites More sharing options...
G+_Joshua Gaede Posted August 25, 2013 Author Share Posted August 25, 2013 It's almost like a connection problem to the server Link to comment Share on other sites More sharing options...
G+_Erin Boudreau Posted August 28, 2013 Share Posted August 28, 2013 I just used mine and it's working fine. Try clearing the data to see if that helps. Link to comment Share on other sites More sharing options...
