G+_David Posted October 15, 2015 Share Posted October 15, 2015 Hey guys and gals, I'm switching to Android and I need some help. My favorite reminder app on iOS is "Due" because it has an auto-snooze, so after the reminder pops up at the time I set, it will keep popping up every 5/10/15/etc minutes until I dismiss it. Is there any reminder/to-do app on Android with the same feature? (I already checked out Todoist and Any.do and it doesn't look like they have it, but let me know if I'm wrong). Thanks!! Link to comment Share on other sites More sharing options...
G+_Sean Patterson Posted October 15, 2015 Share Posted October 15, 2015 Try Life Reminders & RemindMe Link to comment Share on other sites More sharing options...
G+_Joseph Cappellino Posted October 15, 2015 Share Posted October 15, 2015 If I'm not mistaken, this can be done with Google Now Reminders. Basically, you add a reminder (time or location), and once it goes off, there is a notification action to "Remind me in 10 minutes". I don't think the duration is configurable, but it might work for you. The benefit here is that this can be controlled from any device (with Chrome or the Google app), not just Android. Link to comment Share on other sites More sharing options...
G+_David Posted October 15, 2015 Author Share Posted October 15, 2015 Nice, thanks guys! I will give that a try. It also looks like "Remind.me" and "Simplest Reminder Pro" both have auto snooze features as well (and high reviews), so I should be good to go! Link to comment Share on other sites More sharing options...
G+_Tory Harmon Posted October 15, 2015 Share Posted October 15, 2015 Timely does this too. Link to comment Share on other sites More sharing options...
G+_Neil Sedlak Posted October 15, 2015 Share Posted October 15, 2015 Google reminders are also integrated into InBox and Keep, both of which I highly recommend. Link to comment Share on other sites More sharing options...
