Easy Mode Incoming!!!
G+_Matthew Holtzem
I've just submitted version 1.1 of All About Android: The Game to the Play Store so it should be up by the end of the day!!!
In this update I've hopefully addressed some complaints about difficulty by adding an easy mode. In this mode the obstacles are a bit simpler, some of the powerups have been tweaked a bit, and the speed starts slower.
If you've been discouraged by the difficulty so far, update and enable easy mode in the settings menu!!!
https://play.google.com/store/apps/details?id=com.MatthewHoltzem.AAATheGame
