G+_Stephen Hart Posted November 21, 2014 Share Posted November 21, 2014 How do you measure the remaining capacity of a single use AA lithium battery? The standard battery checkers are for a lower voltage battery so they don't work. I'm using pairs of AA lithiums in point/shoot cameras. Link to comment Share on other sites More sharing options...
G+_610GARAGE Posted November 21, 2014 Share Posted November 21, 2014 You can't. Lithium batteries only loose voltage at the very beginning of and the very end of their capacity. So a lithium battery will put out the same voltage; whether it is at 70% or 30%. The only way to know the state of a lithium battery is to know when it is fully charged, and monitor current draw from there. Link to comment Share on other sites More sharing options...
G+_Stede Bonnett Posted November 23, 2014 Share Posted November 23, 2014 That's right, it's one of the reasons knowing your remaining battery capacity on your phone is so hard, and why plugging it in for a few min may appear to restore like half the charge. Link to comment Share on other sites More sharing options...
G+_Stephen Hart Posted November 23, 2014 Author Share Posted November 23, 2014 Just to clarify - this is the single use AA lithium batteries that have about twice the capacity of alkaline AA batteries and are about 1.6 V. Not the rechargeable ones. Link to comment Share on other sites More sharing options...
