I 'm using a Verizon Galaxy Nexus with stable Cyanogen
I'm using a Verizon Galaxy Nexus with stable Cyanogen. I'm holding out as long as I can for a new phone - but the performance issues are really starting to be a pain. Does anyone know if an update to 4.3 will help my phone the same way it helped the original Nexus 7? I noticed that
Jason Howell mentioned he was using a 4.3 ROM on the last show - and it might help. Any thoughts or experiences?
I started clean with Shiny a few weeks ago as its a relatively pure 4.3 AOSP and I have been very happy with the performance improvements. But it's always hard to tell for sure this early cause any wipe and flash of a brand new Rom is going to seem great when you first do it. Having said that, I've been very happy and I'm more and more convinced that the Trim inclusion in 4.3 is helping my GN performance wise.
http://rootzwiki.com/index.php?/topic/36706-[ROM][AOSP][4.3](8/13/13
Funny, I just emailed AAA to ask what ROM Jason Howell was using. I've been using Shiny for a long time (as in 4.1). There does seem to be a difference but be cautious as Jason said. This upgrade was the first I've done a clean install with for a while.
The biggest difference I see between mine on 4.3 and my wife (Shiny 4.2.2) is that my cache is usually less then 10MB while hers is usually in the hundreds within a day of clearing it. I'm on the 8/13 build and was waiting for some stability before moving hers. This one is much more stable then previous ones and I saw yesterday that he just released another. And just a note, Jason's link will take you to the latest, not just the 8/13 build.
Hope another opinion on that one helps.
BTW, he attempts to make this as much like an OTA as possibly so if you like all the customizations in Cyanogenmod, this isn't really for you...
