G+_Eddie Foy Posted March 31, 2015 Share Posted March 31, 2015 Show idea Making PCBs at home. Lots of methods. Pro/semi-Pro: Positive & negative exposure. Iron on transfers: special paper, magazine paper (recycling) 3D print artwork, sharpie. Plus multiple etchants. Some that even can be rejuvenated. Link to comment Share on other sites More sharing options...
G+_Jason Perry Posted March 31, 2015 Share Posted March 31, 2015 Sounds like someone has done quite a bit of research. Link to comment Share on other sites More sharing options...
G+_Taylor Graham Posted March 31, 2015 Share Posted March 31, 2015 I don't really know the specifics, it's been years since i really looked into it. But from what i understand, you can etch copper clad board with an inkjet printer and some acid pretty easily. There is many a guide online. I think it might be easier just to order some from www.oshpark.com, but sometimes you just have to do things yourself. I'd also like to see padre and bryan try it. Link to comment Share on other sites More sharing options...
G+_Eddie Foy Posted March 31, 2015 Author Share Posted March 31, 2015 Jason Perry I've made many a PCB in my kitchen. And with most methods. I toss out ideas I think other might want/should learn. Link to comment Share on other sites More sharing options...
G+_Jason Perry Posted April 1, 2015 Share Posted April 1, 2015 Eddie Foy , I have 2 questions for you then. Which method was the easiest? And which method gave the best results? Link to comment Share on other sites More sharing options...
G+_Eddie Foy Posted April 1, 2015 Author Share Posted April 1, 2015 UV exposure gave best results. But lots of work and care needed. Iron on was easiest. but need to touch up with a sharpie before etching. I haven't tried the magazine pages yet. (seemed a bit ghetto.) Have a few boards in my head to make. Wanna try it out. Link to comment Share on other sites More sharing options...
G+_Ben Reese Posted April 1, 2015 Share Posted April 1, 2015 I've usually seen the magazine method used online. Seems to be pretty simple. Link to comment Share on other sites More sharing options...
G+_Fr. Robert Ballecer, SJ Posted April 7, 2015 Share Posted April 7, 2015 It's been on the build list for almost 18 months... but I be lazy... Link to comment Share on other sites More sharing options...
