Hi first time posting and first major raspberry pi project
G+_Jennings Mercer
Hi first time posting and first major raspberry pi project. Looking for some good info on maybe what someone has tested on or used in the passed? Out line of my project is to make a voltage meter range 0 to 10 volts. With a display, LEDs (1led = 1 volt, 32 led = 10 volts) and and sound that varies as voltage increase. So I can see and hear the voltage increase from a distance. Two leads for voltage input.
I---------------------I
I. Display I
I. I
I. I
I----------------------I
O
LEDs OO
OOO
OOOO
OOOOO
OOOOOO
OOOOOOO
OOOOOOOO
OOOOOOOOO
OOOOOOOOOO
Speaker
Two lead for voltage input
I have a couple 8x16 1.2" LED blocks from Adafruit: http://www.adafruit.com/products/2037
The I2C controller chip makes hooking up and controlling all those LEDs much easier.  I'll post the short video I've got of two of those running through a test sequence in a minute.  Python code to run them is around online.  Someone has even already gotten letters/numbers in python code you could use.
