Does anyone know of a project that can detect the buzzer sound from a washing machine and dryer a...
G+_Raul Thomas
I think similar solutions have been discussed here in the past. Some ideas...
Load sensors on the power lines (measure amperage used)
Gyroscope/motion sensors attached to the side (may give false positives on the washer between cycles)
Hacking in and connecting to lights or other indicators (even the buzzer might work)
You could do a load sensor by making a pass-through on the outlet. Intsead of washer --> wall you have washer --> sensor --> wall. Pick up one of those sensors, read the voltage across it.
Motion can be done with a device on top of the washer (non-invasive)
You might be able to do photo diodes to detect LEDs indicating "done", but you'd need to find a way to filter out other light.?
  • 2 weeks later...
