I have an older phone, Nexus 6 (not 6P)
G+_Daniel Casciato
I have an older phone, Nexus 6 (not 6P). Would like to run Spinrite on the device to see if it will correct the wonky camera action which has developed. Not sure how to get Spinrite running BOSD (I think that is correct) to see the phone plugged into the USB drive. I realize that in 6.1, 6.2 or 7 this will be a no-brainer. Did a search as I am certain Fr Robert has done this successfully in the past. Thanks in advance.
Daniel Casciato? The biggest issue you face is getting the phone to run the USB storage to run in mass storage mode. Running in mtp or ptp will not work. Android dropped USB mass storage somewhere between 4.x and 5.x depending on the flavor of android. You may have to ROM the phone to give you the mass storage support again.
  • 4 weeks later...
