G+_Akos Redey Posted October 19, 2016 Share Posted October 19, 2016 Hi All. I'm using a Synology DiskStation as a NAS exclusively for remote backup via rsync. Is there a way to do local full disk encryption on the DoskStation so that the drives storing the backup can't be accessed if the NAS is stolen? Any link describing it would be much appreciated. Thanks - A' Link to comment Share on other sites More sharing options...
G+_Eddie Foy Posted October 19, 2016 Share Posted October 19, 2016 How are you going to authenticate at boot so the OS/NAS can do the decryption? Link to comment Share on other sites More sharing options...
G+_Ben Reese Posted October 20, 2016 Share Posted October 20, 2016 What it needs is a wireless key that you could hide somewhere nearby. Where's the Synology idea box? Link to comment Share on other sites More sharing options...
G+_Akos Redey Posted October 20, 2016 Author Share Posted October 20, 2016 Thanks for the responses. I'm I run my backups manually, so I'd be able to mount/unmount the encrypted file system manually via SSH, maybe a script. Maybe not whole disk encryption, then. Link to comment Share on other sites More sharing options...
G+_Ben Reese Posted October 20, 2016 Share Posted October 20, 2016 I'd guess client-side would be easier in that case than. Perhaps a ISCSI volume that gets mounted on the client and encrypted with whatever you like. Veracrypt? Link to comment Share on other sites More sharing options...
G+_Ben Reese Posted October 20, 2016 Share Posted October 20, 2016 Or perhaps use CrashPlan to backup to your NAS. It's free for personal use and supports client-side encryption. I'd guess there are other easy ways to encrypt client-side too though. Link to comment Share on other sites More sharing options...
G+_Akos Redey Posted October 20, 2016 Author Share Posted October 20, 2016 Yeah, I am using CrashPlan (with client side encryption), this would be the alternate method, and I'd like it to be completely independent (different/independent crypt, different transmission, location etc.). VeraCrypt would be perfect if Synology supported it. Or if I could create a secure Linux file system (ZFS?) from the HDs. As I have a large backup (say 1 TB) I don't want to dump it locally on the remote server into a Veracypt container, for example, and rsync across the the entire 1 TB file/blob in one go... Link to comment Share on other sites More sharing options...
