I am using a raspberry pi 2 as a NAS device with two external hard drives
G+_John Downey
I am using a raspberry pi 2 as a NAS device with two external hard drives. These drives are USB 2.0 and power by an external power supply. They are plugged directly into the raspberry pi. Since they are four years old and getting full I need to replace them.
Will a Western Digital 4 TB, USB 3.0 external drive work with a Raspberry PI. I want to be able to plug the drive directly into the PI without using a USB 2.0 HUB.
Ben Reese Good point, although it might be that RaspPi does support NTFS: http://raspberrypi.stackexchange.com/questions/32890/how-to-mount-ntfs-drive-on-a-raspberry-pi-b
However, some reading indicates that there are performance issues, probably mostly because of the USB 2 issue.
OTOH I see on my RaspPi that it is using ext4 which would be capable of handling very large volume sizes without issue. Again, just not sure of performance.
I don't see why you would have an issue plugging a USB3 device into the pi, as Steve Martin said they are backwards compatible. However, its over kill and you won't be able to take advantage of the higher communications speed. If you need to buy the WD drive I would suggest saving a bit of cash and buy the USB2 version. If you are getting it free or cheap then don't worry. I think you will be fine. :) Good luck!
