Hey guys having Problems with not being able to pull my S3 Notification bar down to chk msg 's, ...
G+_Hector Sotomayor
What do you mean reset? You mean a factory restore? You can use the Samsung Keis software (I know, I know) make a backup of your settings and messages.
There are also ways to backup SMS message to Gmail http://www.howtogeek.com/112852/how-to-backup-your-text-messages-to-your-gmail-account/
Of use any of the available apps in the Play store like https://play.google.com/store/apps/details?id=com.riteshsahu.SMSBackupRestore&hl=en
I have SMS Backup installed on my phones and was glad to have it there when I had to do a factory restore on my wifes phone. The app makes a backup of your SMS messages to your GMail which. After the factory reset is complete just reinstall the app and perform a restore.
I have used it for both backup and restore. It works!
