G+_menard go Posted May 12, 2017 Share Posted May 12, 2017 Updated my Synology NAS firmware yesterday and lost a shared folder after restart :( Link to comment Share on other sites More sharing options...
G+_Damien Wessling Posted May 12, 2017 Share Posted May 12, 2017 Gee that's lousy man. What kind of RAID do you have configured? Link to comment Share on other sites More sharing options...
G+_Rud Dog Posted May 12, 2017 Share Posted May 12, 2017 Have been pondering buying that NAS would you please post any updates on your scenario? Link to comment Share on other sites More sharing options...
G+_menard go Posted May 12, 2017 Author Share Posted May 12, 2017 Damien Wessling Its actually a single bay version which I bought to play with. Found the problem, encrypted shares have to be remounted after a restart. Rud Dog I am enjoying the Synology software so far, I may buy the 4 bay version with intel processor. Im finding Arm processor a bit slow. Link to comment Share on other sites More sharing options...
G+_Rud Dog Posted May 13, 2017 Share Posted May 13, 2017 Emma Shy Thanks for the info was wondering have you used the Synology software and compared it to the FreeNAS software? Also need to compare the sound each generates along with power consumption. Sleep feature would be great do they both have this feature. Link to comment Share on other sites More sharing options...
G+_Rud Dog Posted May 13, 2017 Share Posted May 13, 2017 Emma Shy Shortly will be coming into Mac OS X, laptop and since FreeNAS is free, will see about using it for testing FreeNas. Thanks. Link to comment Share on other sites More sharing options...
G+_menard go Posted May 14, 2017 Author Share Posted May 14, 2017 I was considering using my old PC but I cant run it 24/7 due to power consumption. Better to use old pc as cold storage and use synology for my frequently used files Link to comment Share on other sites More sharing options...
