Hey guys is there such a thing as power supply monitor software?
G+_Lance John
Hey guys is there such a thing as power supply monitor software? I ask this because I think the added memory maybe affect my power supply  because in the middle of me doing a show or doing some editing work it shuts off on me. This never happen before I added the extra memory.
I removed it and it seems to me working fine now but I sill wanted to know if there was a way to see how much power is been used up with my current config.
When the machine shuts down, does it just cut out? My work machine was doing that not long ago. When i looked inside the machine when it was running, i noticed my GPU fan wasnt running. At first i though the fan had died and was causing the machine to shut off because of high temperature, but the PSU ended up being bad. The gpu probably just wasnt getting the power it needed. I replaced the psu and everything has been fine since. If the machine just cuts out (no bluescreen), your PSU might just be dying, RMA it. Your cpu could be reaching TJ max as well (max temperature), so check your temps with core temp or real temp or something.
I think its possible to test a PSU with a multimeter. You'd just have to pull the psu out, use a wire to start it up, and test the voltages on the 24pin connector. I've never done it before, but im sure google could tell you a good bit about it. A test with a multimeter might not confirm if it will operate properly under load though. Honestly, you might just want to return it.
