Arduino help needed
G+_Richard Hedderly
[iF your size restriction allows..] I don't know about a specific camera but consider the idea used in bigger cameras... extension tubes.  They are extremely simple in that all they do is move the lens away from the sensor/film. For example: On a "35mm" sized sensor/film moving the lens about 2" further away from the normal position will bring focus to about an inch from the front element... or somewhere in that range from memory.  Also, I bet there is a calculator out there that will give you exact measurements of focal length dependent on the lens and sensor size.
There lays the problem though. The camera lens has to be flush to surface it is mounted under. I can't lower the camera to take an extension tube and can't use a tube above the flush level because it has to be... flush.
I'm thinking of using a microscope camera now to get the focal distance.
Ok, one last kinda crazy idea I thought of... Could the camera be set up to "look" into a mirror that would "see" the subject?  The minimum focusing distance would be measured from the camera to the mirror then to the subject. Not likely from your description that it will work for your project but you never know.  Again good luck!
Thanks for the ideas. I've been seeing that people with Raspberry Pi official cameras are unscrewing them to the maximum so that the picture focus is very short.
https://www.raspberrypi.org/macro-photography-with-the-camera-board/
The camera module in the Raspberry Pi official camera is an OmniVision OV5647 which appears to be proprietary with no Arduino library.
There is a short height module that Adafruit do, which has a manual focus, so this should do the same macro focus trick.
https://www.adafruit.com/products/1386
BTW, regarding the mirror approach. I don't have the width to turn the camera module on its side.
