I want to build a floating TV wall I can pull away from my existing wall to get to cables and the...
G+_Albert Rios
I want to build a floating TV wall I can pull away from my existing wall to get to cables and the like by using a few full motion TV mounts to support the wall!
How do I determine how many to use; the load of them are usually 100 lb capacity or more. I was thinking four to be safe but figured I ask the question!
How do I determine how many 100 lb capacity wall mounts would I need; looking for a formular?
If you build a false wall that rests on the floor, you can get away with a lot. Then, attachment to the wall is only for stability. However, I would still use a TV arm mounted to the original wall. Moving a TV away from a light weight false wall would shift the center of gravity significantly it it were attached to the false wall.
Also as a bonus, with an IR repeater, you put things like a Harmony Hub, Roku, or Apple TV in that space to hide them away.
