Hey KITAs, I 'm making a project that has 4 1 amp leds driven by one 18650 battery
G+_James Hughes
Hey KITAs, I'm making a project that has 4 1 amp leds driven by one 18650 battery. It works great but the lights are brighter than I would like. I know that pwm is what I need to use to adjust the light brightness, jus can't find anything small enough to fit in the project. I've looked on amazon, adafruit, sparkfun, and ebay. I guess I need to try bangood and aliexpress. If you know of something I would appreciate a link. Cheers! James
An 18650 battery puts out about 3.7 volts. You didn't tell us how you have your LEDs wired, but assuming they are in parallel, you're sending 3.7 volts to a bulb that is probably rated for 1.7 volts, so yes, it will be very bright (for a little while)
Some LEDs are actually a package, and includes and inline resistor, so that the LEDs can accept higher voltage, but you didn't mention what yours are rated at. If they are just LEDs by themselves, with no inline resistor, that is probably your problem.
If you want to give us more exact information, perhaps we can help you better.
