Will plex for android stream to dlna devices
G+_Joshua Gaede
No. You need the plex app. Easy enough to accomplish what you want. You need a dlna server on your computer. You can also skip that and do what I do. I have a Lacie NAS that has dlna built in. Buffalo makes good ones too. They range from $150 to $200. Totally worth it. I have two Lacie Network Spaces.
