RIP Wapedia Didnt realize it had been 10 years The better mobile interface for searching Wikipe...
G+_Richard Sequeira
  • 2 weeks later...
Looks much better than wikipedia app or wapedia. Could be my go to app for wiki search.
I like the Google+ look on the bar and you may want to consider applying it all across the app.
I agree that a dark theme will be needed but you may also want to consider the Google Now design of white cards on grey background. Then split paras to cards-look. Eg. If I am to search for Leo Laporte, the paras Background and Television and Radio could be on different cards (although they may not need to be active cards that can be swiped away).
Hope this is helpful feedback from an amateur. Good luck. I like it.
