Okay, I think I am going to become hook and get involed in get a "Quadcopter "
G+_Larry Carbaugh
Yuuup... those are the trainers...
Not hard to fly... and they're hard to kill... Also, they don't weigh much, so you're not going to destroy anything... and as long as you don't hit yourself in the eye, they can't really hit you.
Stay tabbed to TWiT... I'm going to do a thing with Leo to show  him basic flight. :)
Definitely recommend some type of "trainer" like the Syma (or more expensive Blade 180qx). Even the small 250 home built quads are a beast to control if you have zero practice. You want something with very little mass so crashes 'hurt' less.
That said. I am enjoying the heck out of my 250. Just added FPV gear to it so it doesnt take long before you out grow the Syma and want more :)
I learned on a Syma and it helped a lot! You can start of inside with prop guards on. With no fans on and it facing away from you, just take it up and hover in place. Once you are comfortable with that you can do small forward and side to side movements with the right stick. As your brain learns what to do you will find that both thumbs are constantly moving. The biggest obstacle is training your brain that quad forward isn't always "left stick away from you". Once you are comfortable with basic movement then try it outside with NO WIND. I recommend launching with the copter facing away and flying away. Now turn the copter with the left stick so that it turns like a car would. This was my "ah ha" brain moment when copter orientation/flight control clicked. Once you have that down. You can fly all you want indoors. I fly mine all over my apartment and in my hotel room when I'm out of town and the weather isn't nice enough to fly my 450 fpv. The biggest thing with the Syma is, its small. If it feels like its out of control or going to do something bad, Chop The Throttle. Better to bounce off the ground than 20 feet up a tree.
All the micro quads I've seen dart around too fast to fly indoors because there's no way to keep them under control because of the lag in the remote.  Unless you have a big open area 3 stories high I wouldn't try it or you will be in trouble for breaking all the wife's lamps, pictures, mirrors, etc.  They take off so fast I can't even keep one in my yard.  The first one I tried took off, went over the house, over the trees, over the neighbor's house and disappeared on the other side of the neighbor's house next to them before the remote could even act to slow it down.
Today I flew my Xtreem QuadForce quadcopter for the first time and only made one mistake.
I ask my wife if she would like to try flying it.
She tell me she will be flying tomorrow wihile I am at work and she told me to buy more batteries with longer flight time.
It came with a 3.7 v 500 mAh battery.
Will a bigger battery work?
I do not remember one of the shows talked about a 5 pack of batteries for $18.00 dollars.
Larry, if you want to build a larger one then maybe a complete kit like the F550 6-Axis FlameWheel HexaCopter on ebay would be a good choice.  The complete kit with everything you need including the batteries and RC transmitter & receiver is only $265. It would be interesting to know if anyone has tried a kit like this and what they think of it.  It's not really upgradeable to a more fancy unit that has GPS and everything though unless the controller and RC components are all upgraded.
http://www.ebay.com/itm/261503138781
