G+_Adam J?va Posted February 5, 2016 Share Posted February 5, 2016 Kernel Booster was updated and issue with dashboard for higher resolution was solved bit.ly/1LcntBX Kernel Booster is must have app for any root user. Kernel Booster is the simplest application for kernel tuning and controlling. Just set a governor and simply tune it for increasing battery life or performance by slider. Kernel Booster also allows you to choose your scheduler according to effect on your battery life, multitasking or performance. You can also modify other kernel features like MIN / MAX frequency settings, CPU idle mode, and many more. #Android #androidapps http://bit.ly/1LcntBX Link to comment Share on other sites More sharing options...
