G+_Adam J?va Posted October 25, 2016 Share Posted October 25, 2016 Auto Memory Cleaner was updated http://bit.ly/1tfsvGd Auto Memory Cleaner is application which cleans your memory effectively to boost speed and performance of your device. Your running processes and their tasks are restarted and not killed what is much more effective and friendly to your device than any other task killer or memory cleaner. This method prevents the memory overflow and also boost speed of your device. Auto Memory Cleaner is running in background and does all the work for you. You can set if you want to clean memory in specific time or every time when screen is turned on/off. Auto Memory Cleaner also allows you to restart any running process manually. http://bit.ly/1tfsvGd Link to comment Share on other sites More sharing options...
