A while back, I would use a 5V regulator and a 9V battery for extra power on the go; like to rech...
G+_Robert Hafer
You will dissipate a lot of power in the regulator. If your sensors are up to it you would be better off with 3xAA Alkaline =4.5V or 4xAA NiMH =4.8V (LSD ones like Eneloop's).
With those you can drive the 5V pin directly. This also bypasses any regulators on the board that you would find in an 'off-the-shelf' Arduino, saving even more energy.
Also, many sensors operate at ~3.3V and you can use 3xAA NiMH or a 1S LiPo (or coin cell or CR123A) combined with boards designed to run at 3-3.3V.
There are years worth of posts at http://jeelabs.org/ on this topic.
