G+_Robert Hafer Posted February 24, 2017 Share Posted February 24, 2017 Hi KITAs, Still thinking about a home automation status display in a 1-gang switch box. I also considering a mini status board with LEDs showing red/green for things like garage door open/closed, alarm set, motion sensors, and similar. My questions are about using a WS2811 strip. Would they stand up to continuous use? I know all LEDs burn out eventually, but e.g. the flood sensor would be on green for years (hopefully); would that significantly shorten its life? The other question is how far apart are the LEDs spaced, so as to figure how many I have space for? Link to comment Share on other sites More sharing options...
G+_Ben Reese Posted February 24, 2017 Share Posted February 24, 2017 If 2812, perhaps something like this? ALITOVE 100pcs WS2812B Addressable LED Pixel light 5050 RGB SMD on Heat Sink PCB Board 1-led LED Module Pixels Light 5V DC amazon.com - Amazon.com: ALITOVE 100pcs WS2812B Addressable LED Pixel light 5050 RGB SMD on Heat Sink PCB Board 1-led LED Module Pixels Light 5V DC: Musical Instruments/ Each light is 10mm diameter. You could definitely put more regular multi-colored LEDs in the same space, but that does seem pretty convenient. Link to comment Share on other sites More sharing options...
G+_Fr. Robert Ballecer, SJ Posted February 25, 2017 Share Posted February 25, 2017 I have a string of WS2812 lights that have been lit 24x7 in a really poorly ventilated enclosure for more than 3 years. Next to a string of new WS2812 LEDs, I can't tell the difference. :) Link to comment Share on other sites More sharing options...
G+_Robert Hafer Posted February 25, 2017 Author Share Posted February 25, 2017 Fr. Robert Ballecer, SJ Thanks, that sounds longer than my Mean Time Between Tinkering. Link to comment Share on other sites More sharing options...
G+_Robert Hafer Posted February 25, 2017 Author Share Posted February 25, 2017 Thanks for the replies; looks like it's time to learn about wi-fi modules and virtual pins for the Arduino. Link to comment Share on other sites More sharing options...
G+_Golden Retriever Posted February 26, 2017 Share Posted February 26, 2017 Can anyone send me a link to the show notes for know how... Link to comment Share on other sites More sharing options...
G+_Ben Reese Posted February 26, 2017 Share Posted February 26, 2017 https://twit.tv/kh Link to comment Share on other sites More sharing options...
