Okay, I couldn 't help myself
G+_Robert Taylor
Okay, I couldn't help myself. Watching the last couple of episodes I got bit by the 3D printing bug. Santa said to treat myself to something special. I found it in the Monoprice Maker Select 3D v2.
So now for a 3D noob - Any suggestions or recommendations? Software, add-ons, advice...
P.S. +Fr. Robert Ballecer, SJ my wallet hates you & +Bryan Burnett
I am really hoping there is a followup episode on the Maker Select, like was mentioned. I got one as well, and have ran through almost 2 kg of filament already! Mostly on upgrade parts. I would be very interested to see which upgrades and tweaks Fr. Robert Ballecer, SJ decides to use. One of the very first ones I did was to replace the tiny 40mm fan in the main unit with a much quieter 80mm, also removed the cover and fan from the internal power supply. The Z braces didn't improve print quality so much, but they really cut down on the need to re level the bed.
* Show Ideas *
Now I am thinking it would be great to control the 40mm fan on the hot end with a Arduino based on temperature. That fan is really noisy and spins whenever powered on, even if the hot end is cold.
While improving print quality is always important, I am also interested to learn what allows some printers to print so much faster than others. Then what can I do to the Maker Select to speed it up!
