Help please so I powered up quad for first time using kk 2 1, everything seemed to come on correc...
G+_Heath Reeder
Help please so I powered up quad for first time using kk 2.1, everything seemed to come on correct and I did the receiver test first, it worked, but then I tried to hold throttle down and to the left to see if motor spin correct but controller keeps beeping and does nothing. My esc all beep as well they will take turns beeping then stop for few seconds them beep again. No clue what is wrong or what to do
ok i dunno what i did but i keep messing with it and all the sudden it armed, but is there a way to test an esc?  one of my motors isnt turning, its not the motor because i hoooked up another esc and the motor spins.  i guess i could take the bullets off the end of the esc to make sure one of those arent loose
