How to use old speakers with only speaker wires as input with a headphone jack?
G+_Probhonjon Baruah
You will need an amplifier (as Robert said, although the one he mentioned might be overkill .. depending on how good your speakers are)
Just go into your local electronics store and tell them what you want to do. You will need the proper size stereo plug to go into your headphone jack, and you will need to have them show you how to wire it up.
