G+_Tony Dunn Posted January 28, 2016 Share Posted January 28, 2016 In Vegas for daughter's 21. I have a note 4, she has iPhone 6. What's an easy way to share photos with out having to txt then back and forth? Link to comment Share on other sites More sharing options...
G+_Erik Flees Posted January 28, 2016 Share Posted January 28, 2016 Google photo might work. Link to comment Share on other sites More sharing options...
G+_Aaron Kimmins Posted January 28, 2016 Share Posted January 28, 2016 Plus the Google photos, auto backup, works on both Link to comment Share on other sites More sharing options...
G+_Tony Dunn Posted January 28, 2016 Author Share Posted January 28, 2016 A little more research, I set up a google photo shared folder. Thanks for info. Exactly what we were looking for. Link to comment Share on other sites More sharing options...
G+_Tony Dunn Posted January 28, 2016 Author Share Posted January 28, 2016 Can I set it so that all photo taken while we are here get put in that folder? Link to comment Share on other sites More sharing options...
G+_Ezar Vasquez Posted January 28, 2016 Share Posted January 28, 2016 Dropbox Link to comment Share on other sites More sharing options...
G+_Travis Hershberger Posted January 28, 2016 Share Posted January 28, 2016 Tony Dunn They have an auto-upload every picture option. You'd just have to remember to turn it off once you're done. Link to comment Share on other sites More sharing options...
G+_Ben Reese Posted January 28, 2016 Share Posted January 28, 2016 I'm not sure you can make it automatically upload to folder, but you can select multiple pics and send them all to the folder at the same time. Long-press the first photo then drag down/up over the other pics you want to select too. Link to comment Share on other sites More sharing options...
G+_Ben Reese Posted January 28, 2016 Share Posted January 28, 2016 BT Sync will work too, but doesn't upload to any cloud service. The pics would be synced directly between the two phones. You can also choose to sync to a PC if you want them backed up there. Link to comment Share on other sites More sharing options...
G+_Mr covert Posted January 28, 2016 Share Posted January 28, 2016 A little off topic but hangouts is a good cross platform chat client instead of SMS. Link to comment Share on other sites More sharing options...
G+_Jon Messenger Posted January 28, 2016 Share Posted January 28, 2016 Google Plus used to have a feature called party mode don't know if they still have it I have not used it in a while but basically everyone that accepts and invent invite to the event can put their phone into party mode so that the pictures they take will automatically upload to the same folder and it was shared Link to comment Share on other sites More sharing options...
G+_G Riedell Posted January 28, 2016 Share Posted January 28, 2016 Ben Reese Did they fix the Samsung/Android to Apple BT file transfers? Last time I tried they didn't like each other... IIRC, incompatible or something. Link to comment Share on other sites More sharing options...
G+_Joshua Hamlett Posted January 28, 2016 Share Posted January 28, 2016 George Riedell iOS does not support Bluetooth file transfer. The best option is to use an app or the cloud. Link to comment Share on other sites More sharing options...
G+_Matt Leo Posted January 28, 2016 Share Posted January 28, 2016 Dropbox photo backup. It'll also make it so that you can share them out easily to others. Link to comment Share on other sites More sharing options...
G+_Tony Dunn Posted January 28, 2016 Author Share Posted January 28, 2016 Google folder working great. Thanks for the ideas everyone. Link to comment Share on other sites More sharing options...
G+_Ben Reese Posted January 28, 2016 Share Posted January 28, 2016 Sorry... BT Sync is Bit Torrent, not Bluetooth. Link to comment Share on other sites More sharing options...
G+_Ben Reese Posted January 28, 2016 Share Posted January 28, 2016 https://play.google.com/store/apps/details?id=com.bittorrent.sync Link to comment Share on other sites More sharing options...
G+_Justin Levy (Just Socia Posted January 29, 2016 Share Posted January 29, 2016 Use Google photos Link to comment Share on other sites More sharing options...
G+_Daniel Casciato Posted January 29, 2016 Share Posted January 29, 2016 There is a WiFi Direct option explained on this page http://bit.ly/1Vwct9v hope it helps! Link to comment Share on other sites More sharing options...
G+_Joshua Hamlett Posted January 30, 2016 Share Posted January 30, 2016 Daniel Casciato Correction to the article you posted: iPhones have had WiFi direct technology for several generations (used by AirDrop) and the last two also gave NFC (used by Apple Pay). The OS, however, restricts use of that hardware to just those applications. If I remember correctly, there is web server technology available for the iPhone as well. I used to use it years ago. Link to comment Share on other sites More sharing options...
