Monitor and check your system informations and data with CPU Hardware and System Infos
G+_Robin Van Gunst
Monitor and check your system informations and data with CPU Hardware and System Infos.
Informations and data are grouped around 13 tabs :
- System giving you all informations on your system like name, model, manufacturer, board, bootloader, kernel architecture or still OS version name.
- Soc giving you informations about your chipset like code, manufacturer name or your GPU. But also dynamic data like CPU Min / Max, CPU Clock Speed, CPU Temperature, Cores, Active Cores, CPU Load for each core. It lets your to monitor your CPU activity.
- Memory with details of internal and external memory
- RAM with details on total RAM, used RAM and free RAM
- Screen with screen size, resolution, density, refresh rate (fps) or still brightness
- Battery with battery health, level, power source, status, technology, temperature or voltage
- Thermal infos from CPU, Battery and Ambient Air Sensor
- Sensors listing all you device's sensors and showing their values in real time
- Cameras listing all you cameras with for each of them max resolution and supported resolutions
- Mobile that presents your all informations about your smartphone like Device ID (IMEI for GSM), Device Type, Network Operator, Signal Strength, SIM Serial Number or still phone activity
- Network showing you your connection type, Wi-Fi signal strength, IP Local and External, MAC Address, SSID and connection speed
- Bluetooth showing details like device name Bluetooth address
- Location showing location is enabled, location sensor type used and also your last position (latitude / longitude)
https://play.google.com/store/apps/details?id=com.ssaurel.cpuhardwareinfos&rdid=com.ssaurel.cpuhardwareinfos&hl=en
#android #indiedev #appmarketing #cpu #soc #system #hardware
