G+_Sudjoko Huang Posted August 4, 2013 Share Posted August 4, 2013 VolumePlus (Volume Boost) This application was designed primarily to boost the volume of a wired headset. Whilst it will boost the main loudspeaker volume, it may not be as prominant. Using VolumePlus your phone will get a boost in bass, treble, and if you're using our presets, you can finally experience the quality of music that you truly deserve. Being system wide, VolumePlus works with Google Music, Pandora, Slacker, and every other music software on your device (that doesn't have a built in EQ). Volume+ might not get you the same experience that you get with those over priced headphones, but what we can promise you is that for $2, you will get music that is finally worth listening to. https://play.google.com/store/apps/details?id=com.hzsoft.volumeplus https://play.google.com/store/apps/details?id=com.hzsoft.volumeplus Link to comment Share on other sites More sharing options...
