G+_Adam EL-Idrissi Posted December 10, 2014 Share Posted December 10, 2014 Getting a norco Rpc-430 4u case and installing i3-4130 on a micro atx motherboard and 6 hard drives. The case has 2 80mm fans and I was wondering what would be recommended for an efficient fan but as quiet as possible? Link to comment Share on other sites More sharing options...
G+_Travis Hershberger Posted December 10, 2014 Share Posted December 10, 2014 I just replaced a couple generic, loud, and failing 120mm fans in a case at work with a couple Corsair SP120 series. Big difference, and would have replaced all the fans in the case, but those Corsairs have a 4pin connector (most of the connectors available in this case are 3 pin.) Also, in the future, if you're concerned about noise it's much better to buy a case made with sound dampening in mind. Link to comment Share on other sites More sharing options...
G+_Adam EL-Idrissi Posted December 10, 2014 Author Share Posted December 10, 2014 Thanks guys. Ive heard good things about noctura.I'm moving my server from my bed room closet to either the hallway closet or attic (insulated from outside weather) and didn't want to hear a jet. Last server I had was a 1u and I just assumed a 4u would be just as loud or close. Link to comment Share on other sites More sharing options...
G+_Travis Hershberger Posted December 11, 2014 Share Posted December 11, 2014 With only 2 80mm fans plus the power supply and processor fans it shouldn't be too bad. Noisier than a nas box, but not by much. Link to comment Share on other sites More sharing options...
G+_Adam EL-Idrissi Posted December 11, 2014 Author Share Posted December 11, 2014 Ron Reifsnider? I went on YouTube to look at hwc videos and found this: Fractal Design DEFINE R5 Review | Silent Case Per…: I'm sold. Link to comment Share on other sites More sharing options...
