Simple question,Can you use a combination of unmanaged and managed switches with vlans and link a...
G+_Adam EL-Idrissi
For those familiar with audio, you could also think of unmanaged switches as headphone splitters, whereas managed switches as aux outputs on a mixer. You can do different things with all the different aux outputs, but if you hook up an unmanaged switch anywhere, it will just repeat the same things along, no change. And yes, you can use unmanaged switches alongside managed, if you keep this in mind.
I don't believe that is correct...I'm not sure why it would break it, there's nothing to "strip." It's simply the main managed switch acting with some primitive routing functionality, and not linking certain ports (or in other words, acting like two or more discreet switches). If you have 2 ports that are their own vlan, if you add an unmanaged switch to that, it would only add more ports to the vlan, not break anything.?
Well, I think there actually is something that identifies the VLAN that each packet belongs to (http://wiki.wireshark.org/VLAN), but the issue is whether or not the switch cares the the packet has extra data in the header.
Looking into it a bit more, I found this: http://blog.thelifeofkenneth.com/2014/03/pushing-vlan-tags-through-unmanaged.html. It turns out all the unmanaged switches he tested processed larger packets they actually had to. This could be a security risk waiting to happen, but it also should allow the VLAN tagged packets to pass on through.
