Silly question: for a strictly torrent box, does cpu speed # of cores do anything?
G+_Adam EL-Idrissi
It depends on your network speed.... If you've got a Gb internet I'm extremely jealous! But also, yes, that will hut your CPU! If you've got 20Mb, then no, anything will be fine.
What I have found to matter is the RAM (and to a certain extent the CPU) in your router. So if you have el cheapo router, you may see an improvement if you buy a nicer one!
That said, you should be able to see the routet struggling... So I'd setup the box first & then only worry about the router if need be
Happy Torrenting!
John Mink I've got 75 down and a dual core atom pfsense box. I wish I had gb speeds! But $200/month for 2gb/100mb from Comcast is way too much for home use. I get a lot of Linux iso torrents and torrent the defcon media server. I'm not doing any encryption (other than vpn) so I think that won't be an issue.
