G+_Bostjan Cadej Posted October 1, 2016 Share Posted October 1, 2016 Hi I have some questions about batteries and electricity. First a general question. Does it matter if I use battery with 1 V and 10 A – can I also use battery with 10 V and 1 A? Does it matter? Second question. I have 5 V battery on which it also says 700 mAh. Can I replace this battery with 5 V with 1400 mAh? Thanks for answers. Link to comment Share on other sites More sharing options...
G+_Riley Plays Posted October 1, 2016 Share Posted October 1, 2016 Yes on the second question. mAh just stands for (milliamp hours) So the more mAh the more running time. Link to comment Share on other sites More sharing options...
G+_Ben Reese Posted October 1, 2016 Share Posted October 1, 2016 1V, 10A and 10V, 1A have the same wattage but aren't necessarily interchangeable. Typically the power source will determine the voltage and the load will draw whatever amperage it needs. For example, if you have 240V service and you connect a 60W bulb then the light will draw 0.25A. If you connect the 60W bulb to 120V service, it will draw 0.5A. In both cases the service might have a 15A breaker/fuse, but the load will only use the amperage it needs. Link to comment Share on other sites More sharing options...
