I ordered a light kit that blinks when my battery is running low, which should help me with crash...
G+_Eddie Hughes
I ordered a light kit that blinks when my battery is running low, which should help me with crashes ;). The only problem is that it connects to the battery balance connector and I was wanting to use that for FPV flying, which also connects to the battery balance connector. Would it be safe to make a female to two male balance connector to connect to my battery and then to the light kit and FPV filter thingy or do I have to chose one over the other?
