G+_Jeremy Webb Posted March 22, 2016 Share Posted March 22, 2016 I was wondering what best practices for selecting the correct wire for my projects. What gauge should I use? Is it better to use braided or solid core wire? Link to comment Share on other sites More sharing options...
G+_Steve Martin Posted March 22, 2016 Share Posted March 22, 2016 Jonny Ramos is correct, but there are other things to consider: Solid wire is typically cheaper for the same current requirements. It's downside is that it is easy to break if flexed. Stranded wire can be more expensive and require a thicker wire for the same current. It is more flexible and should be used where the wire will be bent frequently or where you need to place the wire in a tight bend. Even if it won't be flexed much after installation. Link to comment Share on other sites More sharing options...
G+_Eddie Foy Posted March 22, 2016 Share Posted March 22, 2016 You never stated the 'projects' (the question is akin to 'how long is a piece of string?') Plenty of charts on the web for current/voltage carrying per gauge. I always look it up. I can guess from memory and probably be right, or look it up and be right. Some things need to be verified. Voltage dielectric and temp of the insulation are a factor too. Its not uncommon to use a small wire gauge but a higher temp to handle more current. (though I'd would recommend that unless weight is a major factor) And just to toss a oddball wrench in the works, DC travels down the center of the wire while AC tends to run on the outer skin. Link to comment Share on other sites More sharing options...
G+_Bill Boelke Posted March 23, 2016 Share Posted March 23, 2016 if your questions is as basic as sizing the wire, you need to consider the maximum flow the wire is anticipated to carry and prevent that wire from becoming a fuse because it cannot carry the load without burning up or starting your project on fire. Not only are you concerned with the max amps that would normally flow, but you should also consider a safety factor for when things go awry. Link to comment Share on other sites More sharing options...
G+_Larry Havenstein Posted March 23, 2016 Share Posted March 23, 2016 If I remember my electronic theory right and the skin effect, stranded wire can carry more current than solid wire due to more skin surface area. Its along the same idea as many small ice cubes cool faster than one big ice cube. Its about surface area. Link to comment Share on other sites More sharing options...
