I 've a quadcopter problem I need help with:
G+_Mr ROKnBOK
Mr ROKnBOK Your computer doesn't give off much of any magnetic field, assuming it's properly enclosed. We have one of those field detectors at work and actually measured what a computer puts out, the only area with any magnetic field was behind the power supply.
If it's just a slight drift, you should be able to correct it by adjusting the flight controller. Most of them have buttons beside the joystick to adjust for that.
