I am trying to determine if my Nexus 6 (XT1103) with Lollipop (6 0 1 (build: MMB29K) has MHL comp...
G+_Daniel Casciato
I am trying to determine if my Nexus 6 (XT1103) with Lollipop (6.0.1 (build: MMB29K) has MHL compatibility. A website http://pdadb.net/index.php?m=specs&id=6982&view=1&c=google_nexus_6_xt1103_td-lte_64gb_motorola_shamu - shows that it has "USB Series Micro-B (Micro-USB) with MHL connector" compatibility. If this is true could you suggest a cable/adapter? Thanks - really need this to work...
I have chromecast and fire stick. Love "email. Problem is using them at the cabin which has no wifi. Using my phone as a hotspot is not economical (limited to 7 GB per month). Phone data is unlimited and want to stream from handset directly. I have tried the activate hotspot on another LTE handset (dummy hotspot), and then turn off LTE data on the dummy hotspot with no luck. Chromecast wants to hand off data stream to the dummy hotspot device. Miracast from Nexus 6 has been deactivated by Google. I have tried the build.prop suggested modification with no joy.
