G+_Brian “Yikesfpv” Gipe Posted June 28, 2016 Share Posted June 28, 2016 Hey guys. I have a question. I got a new motor for my diatone 150. It's the same motor in name but I can tell the size is different. Won't spin no matter what I do. Will they not work if not exactly the same. Here is a link: http://www.readytoflyquads.com/rtf1306-brushless-micro-motors-kv3100 Maybe I have to get another set and change them all out? Naze32 running cleanflight btw. http://www.readytoflyquads.com/rtf1306-brushless-micro-motors-kv3100 Link to comment Share on other sites More sharing options...
G+_Travis Hershberger Posted June 28, 2016 Share Posted June 28, 2016 Can you hook the flight controller up to a computer and look to see if the radio is sending a signal? Link to comment Share on other sites More sharing options...
G+_Brian “Yikesfpv” Gipe Posted June 28, 2016 Author Share Posted June 28, 2016 I'll have to check it when I get home. What tab would that be in cleanflight? Link to comment Share on other sites More sharing options...
G+_Travis Hershberger Posted June 28, 2016 Share Posted June 28, 2016 I'd have to look when I get home as well. Link to comment Share on other sites More sharing options...
G+_Brian “Yikesfpv” Gipe Posted June 29, 2016 Author Share Posted June 29, 2016 Not sure how to tell if my motor is getting a signal but the radio is working fine. Might try and connect my other ccw motor to see if that works. So frustrating I can't fly! lol Link to comment Share on other sites More sharing options...
G+_Brian “Yikesfpv” Gipe Posted June 29, 2016 Author Share Posted June 29, 2016 Do some motors only spin one direction? Maybe i just need to switch a couple wires. Link to comment Share on other sites More sharing options...
G+_Brian “Yikesfpv” Gipe Posted June 29, 2016 Author Share Posted June 29, 2016 Think I can use the blheli passthrough too. Link to comment Share on other sites More sharing options...
G+_Brian “Yikesfpv” Gipe Posted June 30, 2016 Author Share Posted June 30, 2016 Crap! Think I might need a new FC. Actually have one on hand. Naze32 ftw. Lots of soldering practice. Still not any better. :) Link to comment Share on other sites More sharing options...
G+_John Sullivan Posted June 30, 2016 Share Posted June 30, 2016 contact readytoflyquads.com and ask them. Link to comment Share on other sites More sharing options...
G+_Brian “Yikesfpv” Gipe Posted June 30, 2016 Author Share Posted June 30, 2016 I didn't want to but I switched out one of my working motors and the new ones work fine. I'm gonna switch out the ESC again. Failing that I think the FC is the problem. Link to comment Share on other sites More sharing options...
G+_Brian “Yikesfpv” Gipe Posted July 2, 2016 Author Share Posted July 2, 2016 It's alive!!!!!!! New FC fixed the problem. For some reason. But anyways. I'm back in the air, mofos!!!!!! Link to comment Share on other sites More sharing options...
G+_Brian “Yikesfpv” Gipe Posted July 2, 2016 Author Share Posted July 2, 2016 And with new 4s power. I can now destroy my rig that much faster! Link to comment Share on other sites More sharing options...
