Any recommendations for a battery charger, the battery I 'm getting is a 3s 1500mah 35C
G+_Oliver Jackson
Any recommendations for a battery charger, the battery I'm getting is a 3s 1500mah 35C lipo http://www.hobbyking.com/hobbyking/store/__34631__ZIPPY_Compact_1500mAh_3S_35C_Lipo_Pack_UK_Warehouse_.html
Also, any general tips for safety, is it worth getting one of these:
http://www.hobbyking.com/hobbyking/store/__74052__Turnigy_TGY_AVT01_Voltage_Sensor_UK_Warehouse_.html
Is it the case that things like phones that use lipo batteries don't need this because they already have the circuitry? So the components won't draw so much that the voltage levels become unsafe? However with quad copters you have no such circuitry and going below a certain voltage damages the cells?
Just curious that's all, this community is so awesome, really helpful and always full of great ideas. Cheers.
For a charger, I've been having success with a clone of the IMAX B6:
http://www.amazon.com/gp/product/B009VCBC2I?psc=1&redirect=true&ref_=oh_aui_search_detailpage
But if you're shopping at HK, they sell a "genuine" IMAX here:
http://www.hobbyking.com/hobbyking/store/__58285__IMAX_B6AC_V2_Professional_Balance_Charger_Discharger.html
For monitoring the voltage, that sensor you linked to is a telemetry device that only works with certain transmitter/receiver combos. If you're using a KK controller it already has a  voltage sensor, you just need to wire it in, it will emit a loud beeping when the voltage drops below a configurable threshold. Otherwise most people seem to use these:
http://www.hobbyking.com/hobbyking/store/__18588__HobbyKing_8482_Cell_Checker_with_Low_Voltage_Alarm_2S_8S_.html
My understanding of how/why they label the batteries is a bit limited - maybe someone else can expand on this? But In reality the voltage will vary depending on how charged your battery is, up to 12.6V. From my own recent conversations about "how do you know if you're discharging your battery too much" 11.1 might just be the lowest charge you want to have to keep your battery in good health.
