G+_Chad Troyer Posted December 30, 2013 Share Posted December 30, 2013 Please help! I'm looking for a cheap NEW Android phone/device that can serve as a music/navi device for my car. Hopefully something less than $100 without any contracts... Here are my requirements: - 4 to 5 inch screen (preferably not AMOLED since it will not be easy to see in direct sunlight in my car) - Dual core CPU or better - Bluetooth A2DP (preferably Bluetooth 4.0 and AptX support) - MicroSD card support - Full GPS antenna (which pretty much everything has nowadays) - Carrier and locked/unlocked doesn't matter since I won't be using the cellular support - Optional but very helpful: Native or easy CyanogenMod support so that it can stay up-to-date with apps and the O.S. I've been looking at the Samsung Galaxy S3 but they aren't quite under $100 unless they are used and (often) damaged in some way. Sorry for the complicated requirements at such a low price point but hopefully you guys can provide a good suggestion that is as close as possible to what I'm looking for. Thanks!! Link to comment Share on other sites More sharing options...
G+_Mike Kruzel Posted January 1, 2014 Share Posted January 1, 2014 Take a look at the Droid Ultra. Its a 5 inch screen and has a dual core processor. Link to comment Share on other sites More sharing options...
