So I need some help
G+_Cameron Bentley
So I need some help. Just got a Syma quad and it does not seem to want to lift off correctly. I synced on a level surface and when I apply thrust it will lift off but quickly flip and crash into ground. I have only been able to get the gyro to calibrate correctly 2 times out of the about 50 times I have tried. What could be the problem? Is it a bad flight controller? Any help would be appreciated. Thanks Guys love the show!
I've got a tutorial for this that I was planning on using in late Feb... but you need it now, so... let's do it! :)
1. Put the quad on a level surface.
2. Turn on the transmitter
3. Turn on the Quad and let it go to slow-blink
4. Sync remote
5. Push BOTH sticks full down and to the right
6. The Quad will fast-flash: This means that it's recalibrating
When it's done flashing, it should be set to fly!
Enjoy. :)
