G+_Robin Wilkinson Posted March 8, 2013 Share Posted March 8, 2013 Great episode on wireless audio, guys. I've got an idea for another one along the same lines but simpler. I've got a large sound system in my living room connected to a Pc, and frequently listen from the kitchen or other rooms. I'd basically like to use an ipad as a remote for browsing my library instead of having to go back to the computer every time to change songs or volume. It would be neat at parties to have the ipad just floating around the room with the guests picking the next songs. I've used Teamviewer, but it's a bit cumbersome for this sort of thing. I think there are better solutions out there, and I think exploring them would make for a good show. Cheers! Link to comment Share on other sites More sharing options...
G+_Jim Rodgers Posted March 8, 2013 Share Posted March 8, 2013 Robin, if you load XBMC on your PC in your Living room you could Airplay the music from the iPad to the PC Link to comment Share on other sites More sharing options...
G+_Robin Wilkinson Posted March 8, 2013 Author Share Posted March 8, 2013 Thanks, for the advice Jim. The library resides on the PC, (or NAS, actually) not the ipad. Link to comment Share on other sites More sharing options...
G+_Colin Nelson Posted March 8, 2013 Share Posted March 8, 2013 Xbmc can be controlled via a web portal or an iPad app. I do something similar already using a raspberry pi running xbmc and connecting to my pc that hosts the library and I control it via my iPad! Link to comment Share on other sites More sharing options...
G+_Robin Wilkinson Posted March 8, 2013 Author Share Posted March 8, 2013 Thanks very much guys, I'll give it a try. Link to comment Share on other sites More sharing options...
G+_Robin Wilkinson Posted March 8, 2013 Author Share Posted March 8, 2013 Yet another option! Thank you!! See? This would make a neat show. Link to comment Share on other sites More sharing options...
