G+_Jonathan Brown (Chronic Posted July 22, 2015 Share Posted July 22, 2015 Hey guys! I'm wanting to expand my computer and mobile device repair for friends and family into a more professional business and wanted to know if anyone can recommend tools or a tool kit for my bench and one for my in-home jobs. I have an assortment of tools now but most are cheap and I need something that looks more professional and will last longer than a few uses. Thanks in advance for any help you can offer! Link to comment Share on other sites More sharing options...
G+_Erik Ellsinger Posted July 22, 2015 Share Posted July 22, 2015 iFixit toolkit Link to comment Share on other sites More sharing options...
G+_Jonathan Brown (Chronic Posted July 22, 2015 Author Share Posted July 22, 2015 They good quality? I've heard they were cheaply made. Erik Ellsinger? Link to comment Share on other sites More sharing options...
G+_Eddie Foy Posted July 22, 2015 Share Posted July 22, 2015 iFix it are ok tools. A bit over priced, not the best, but not junk either. For computer repair they aren't going to see tough use. I like Wiha, x-celite, Bondhus for the smaller tools. Craftsman of course is in the mix (great return policy) Snap-on is WAY over priced for 'puter repair. The house brands @ Lowes/Home Cheapo are so-so in quality. High quality screwdrivers are a must. I really don't like the interchangeable bit style. The barrels/shafts are too thick to reach places quite often. When using Philips, always insert and give a little wiggle. If there is slop, next size up or risk stripping the head. There are 2 type of Philips standard and Japanese. (Jap can be identified by a dot on the head) theses heads have a more square cut to them, its a much better design. If its a dual head flat/philips (actually tri, you can use Robertson bits (square) on them) go for Philips. In a pinch Allen keys (usually standard) can work on torx fasteners if not too tight Link to comment Share on other sites More sharing options...
