G+_Joel G. J Posted September 14, 2014 Share Posted September 14, 2014 Fr. Robert Ballecer, SJ Bryan Burnett Best hard low cost for $$ hard drives for Dell XPS 410? What is similar to the Dell's official OEM hard drive. Computer is ~10 years old. Sata2 ?Got an error message from Windows that both 320GB drives are failing. DON"T NEED SSD!!!! http://accessories.us.dell.com/sna/productdetail.aspx?c=us&l=en&s=dhs&cs=19&sku=342-3006&mfgpid=167776 http://accessories.us.dell.com/sna/productdetail.aspx?c=us&l=en&s=dhs&cs=19&sku=342-3006&mfgpid=167776 Link to comment Share on other sites More sharing options...
G+_Ben Reese Posted September 14, 2014 Share Posted September 14, 2014 There are probably better prices on Amazon (like http://goo.gl/DTPR09), but that should work. Might consider a cheap SSD though if it's a computer you'll be using much. Should breath new life into an old computer. Link to comment Share on other sites More sharing options...
G+_Joel G. J Posted September 14, 2014 Author Share Posted September 14, 2014 Are the Blue's a good option? Link to comment Share on other sites More sharing options...
G+_Ben Reese Posted September 14, 2014 Share Posted September 14, 2014 Honestly, I'm not real up on all their different variants and categories. I think Green is for power efficiency and Black is performance. Blue seems like it might be their budget friendly line and I think Padre has mentioned that Red is designed for RAID. This forum discusses the difference between Blue and Black some: http://www.tomshardware.com/forum/282860-32-blue-black Link to comment Share on other sites More sharing options...
G+_Travis Hershberger Posted September 14, 2014 Share Posted September 14, 2014 That's just another desktop (sorry, but it is) so any SATA hard drive will work with it. SATA is always backwards compatible, so if you get a SATA III 600mbps HD you can plug it into a SATA II 300mbps port and it will work just fine. Let's face it, spinning hard drives will never keep up with a SATA II interface let alone a SATA III. The only time you'll see a speed difference is when the drive has information being requested in its cache. Link to comment Share on other sites More sharing options...
G+_Fr. Robert Ballecer, SJ Posted September 14, 2014 Share Posted September 14, 2014 Joel J Let's work it in a different direction. What do you want to be able to do? How much do you need to store? How redundant does that storage need to be? How much do you want to spend? -- Any answer for "the best storage" needs to have that data. :) Link to comment Share on other sites More sharing options...
G+_Joel G. J Posted September 15, 2014 Author Share Posted September 15, 2014 It's just a desktop & it's only a mediator computer to the laptops we have. Soo, the blue drives are probably what we need. FYI: Fr. Robert Ballecer, SJ, I might post another computer question later in the group. This is an awesome community for all the queries I have :] ? Link to comment Share on other sites More sharing options...
