NEED HELP! Wondering if anyone is experiencing this: My fonts on my Vizio 30 inch screen are blu...
G+_Rud Dog
NEED HELP! Wondering if anyone is experiencing this: My fonts on my Vizio 30 inch screen are blurred both in game and on my browser. Have tried all the adjustments recommends (from my Google searches but no luck.) This was not the case in the distant past something has changed somewhere along the timeline. Do I need a new monitor for a PC with Higher resolution or am I barking up the wrong tree??
How far away from the TV are you viewing it? The television is not meant to be viewed less then 1 feet away like a monitor? Meaning, is it blurry no matter where you sit? Is it blurry no matter what device is plugged into the TV? The HDMI cable or HDMI output of the PC plugged into the TV might be going bad.
I am about 4 feet from the screen but note, there was none of this blurriness before it something along the stated timeline has changed. I used an exact copy monitor and still had the same problem. Gonna try and play with the adjustments some more and see what can be done to improve the viewing pleasure. Thanks
