G+_Eddie Foy Posted February 13, 2015 Share Posted February 13, 2015 Finishing up my 550 HexCopter build. Still can't figure out how to hold down the battery. (putting it between bottom/top plates.) But thought of a good way to hold down the Flight Controller, RC rx, telemetry x-ciever etc. The 3M Command strips! Very light and with a good rubbing alcohol cleaning/prep, it will hold great. Link to comment Share on other sites More sharing options...
G+_Eddie Foy Posted February 13, 2015 Author Share Posted February 13, 2015 Harold, so you want a little drone-porn? I'll take a few pics soon. The standard wiring/cabling bother the *&&%$^^ out of me. (I'm a wiring Himmler ) I plan on making my one power/signal frame-plate. (less weight, I am the gram-Miester also) Link to comment Share on other sites More sharing options...
G+_UAV Pirate Posted February 14, 2015 Share Posted February 14, 2015 I like a layer of 3/4 inch soft foam with battery sitting on top. Squish down battery and then use Velcro strap to hold down. This is nice especially if you have a variety of battery sizes. The compressed foam holds enough tension to keep batter from sliding around. Link to comment Share on other sites More sharing options...
G+_JON Posted February 18, 2015 Share Posted February 18, 2015 Another multi-rotor fan. Welcome to the skies! Link to comment Share on other sites More sharing options...
G+_Eddie Foy Posted February 18, 2015 Author Share Posted February 18, 2015 I'm that not new. Have the DJI Phantom 2 for nearly three years now. Link to comment Share on other sites More sharing options...
